N noobatcomps Distinguished May 11, 2009 5 0 18,510 May 15, 2009 #1 I need suggestions for a computer case with a cool alien-ware look while in my budget. My budget is $80.
B bbr147 Distinguished May 11, 2009 7 0 18,510 May 15, 2009 #2 Why don't you look for one yourself? We probably have different tastes than you do, and we won't be able to pick the one which is best for you. Just go down the list, and look for the case you like best: http://www.newegg.com/Product/ProductList.aspx?Submit=Property&Subcategory=7&Description=&Type=&N=2010090007&srchInDesc=&MinPrice=&MaxPrice=80 I personally like these two cases: COOLER MASTER RC-690 http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137 Antec Three Hundred http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042 But I don't really like the whole Alienware look, so you'll probably be able to find one that you like better than those.
shortstuff_mt Glorious Apr 1, 2008 10,191 26 43,965 May 15, 2009 #3 Here's a list of $50 - $75 cases off Newegg: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010090007+4026+1054808287+1295819209+1055508421&QksAutoSuggestion=&Configurator=&Subcategory=7&description=&Ntk=&CFG=&SpeTabStoreType=&srchInDesc=
nerrawg Distinguished Aug 22, 2008 500 0 18,990 May 15, 2009 #4 You know you can buy alienware cases if that's what you want. They aren't as good as the antec 300 though Here is one for sale in the UK - must have them in the US as well: http://www.ebuyer.com/product/148400
N noobatcomps Distinguished May 11, 2009 5 0 18,510 May 17, 2009 #5 Thanks for the suggestions but I found one on my own.
M mark_k Distinguished Dec 31, 2008 610 0 18,990 May 17, 2009 #6 noobatcomps : Thanks for the suggestions but I found one on my own. Thanks for sharing.
