So I just got a 3 pack of Corsair LL120 fans and was wondering is there was anyway to have the good side of the fan showing as an intake. Right now, if the fan is in the intake position all you see is the motor and supports and things.
D
Deleted member 2720853
You mean seeing the side without the supports while looking inside the case? Not possible. Fanblades are made to blow air in one direction and you can't change that unless you flip the fan around, which would then make it act as an exhaust.
