Cooler 4 overclocking a fx 8300
MSiFan4DaWin
Commendable
Aug 14, 2016
37
I would like something that will do the job done for getting it to 4 ghz and keeping it under 80* C.
I dont want a coolermaster 212 evo and i want it to be under 50$
80C is waayyy too hot for an FX CPU. Because the thermal sensors are further away from heat producing components in the FX series, they need to be kept at a lower reported temperature. An FX CPU will throttle at about 65C core and 55C CPU.
For a 700MHz overclock, I would recommend the Noctua NH D15.
i was thinking at a deepcool lucifer k2 or a REEVEN Steropes RC-1206 because noctua products are waay overpriced in my country.
The Lucifer is a huge cooler and may cause RAM clearance issues. And to be honest, the Reeven model OP suggested and the Phanteks model Karadjgne suggested both don't list a recommended TDP.
However, it seems that the Phanteks model is has more surface area and would likely do a better job.
