i have a 9900k, i dont overclock or any of that jazz. I'm currently running WoW at graphic settings '7' and have been for a few hours, my cooler is not functioning properly. it is 120mm AIO, i can hear the pump going every now and then, but the fan part does not work at all. I have a fan that does work between the broken fan and the case, that blows air out.
my temps are surprisingly stable, at the high 60's - low/mid 70's for the 'Max' value under HWmonitor. based on this information, what would you recommend i replace my half broken 120mm AIO with? i am a complete computer nub, and this will be the first time ive tinkered with a computer like this lol.
i would like to know what kind of thermal paste i should use, and what kind of cooler i should get. i was intending on going for a 240mm AIO, but looking at my temps with a half broken 120mm AIO, i am now wondering if a 240mm is overkill.
thx for taking time to read this
