[SOLVED] Cooler BeQuiet Dark Pro 4
Rebelz86
Commendable
May 12, 2019
58
4
1,545
Hi guys I need help with my cooler that I wanna buy for my amd ryzen 7 3700x , so my pc specs are : B450 Elite Motherboard ATX , 16gb Ram , RX 580 8 gb VRAM, and my case is a Mid Tower AeroCool Shard, Im curious if I can fit this cooler in my case , my motherboard is compatible with the cooler , but Im not sure about the case can u guys help?
Phaaze88
Ambassador
Oof. About 2mm too tall(157mm).
These all fit:
SE-225-XT: https://altex.ro/cooler-procesor-id-cooling-se-225-xt-2x120mm/cpd/CSASE225XT/
SE-234-ARGB: https://altex.ro/cooler-procesor-id-cooling-se-234-argb-120mm/cpd/CSASE234ARGB/#additional
SE-224-XT Basic: https://altex.ro/cooler-procesor-id-cooling-se-224-xt-basic-120mm/cpd/CSASE224XTBASIC/
SE-224-XT ARGB V2: https://altex.ro/cooler-procesor-id-cooling-se-224-xt-v2-rgb-120mm/cpd/CSAE224XTARGBV2/#additional
SE-224-XT RGBhttps://altex.ro/cooler-procesor-id-cooling-se-224-xt-rgb-120mm/cpd/CSASE224XTRGB/#additional
[RGB/ARGB - check motherboard headers! RGB = 12v, ARGB = 5v.]
There's a couple brands I'm not familiar with in that store. Plenty from ID-Cooling.
Phaaze88
Ambassador
CPU Cooler ClearanceSupports CPU coolers up to 155mm
https://www.bequiet.com/en/cpucooler/1378
Dimensions (L x W x H), (mm)146 x 136 x 163
Phaaze88
Ambassador
Scythe FUMA 2(154.5mm)
Silver Arrow 130(130mm)
Not too many out there that'll maybe match the DRP4 and be that short.
A few others:
Thermalright Assassin King 120 Plus(154mm)
Vetroo V5(148mm)
ID-Cooling SE-224-XT(154mm)
Phaaze88
Ambassador
Rebelz86
Commendable
May 12, 2019
58
4
1,545
Alright is there any water cooler good for this case? I mean I want a watercooler good enough to handle OC if not imma just throw this case in the garbage and buy a new one
Phaaze88
Ambassador
You went from, "I want an Air Cooler, no matter the price", to "I want a watercooler good enough to handle OC"...
Are the FUMA 2 and Silver Arrow 130 not available for you?
The Aerocool Shard officially supports front mounted radiator only, up to 240mm, but that's no good, due to the front panel.
Optimal location for an AIO radiator is an open mesh panel, so you don't stack up on the air resistance and choke them. Air coolers have the advantage here since they're located towards the center of the chassis.
Phaaze88
Ambassador
These all fit:
