I'm working to replace the cooler on my old build from 2016. I have a Asus M5A97 LE R2.0 ATX AM3+ Motherboard and a AMD FX-6300 3.5 GHz 6-Core Processor. I was using the cooler that came with the processor for years with no issues, but over the last few months, the cooler fan stopped working, so I thought I would go ahead and upgrade. I bought a Cooler Master Hyper 212 cooler, which according to PC part picker is AM3 compatible. Unfortunately, when I went to put it on my PC, the mounting brackets don't fit AM3, and the manual says it's only AM4/AM5 compatible.
Does anyone know if I can just buy new mounting brackets to fit it on my AM3 MB or do I need to use another cooler all together? If not, any recommendations for an AM3 compatible cooler?
Thanks for the help!
