Cooler for Antec Nine Hundred case
nkarasch
287
I am torn between the Zerotherm Nirvana and Thermalright Ultra-120 Extreme. I was leaning towards the Zerotherm because it is $50 and the TRUE is $60 and still requires a fan so it will be closer to $70-75.
Question: The Zerotherm only has one fan and its premounted. It is not a standard size fan you can just replace or face either direction. Can I bring air in the back of my case and exhaust it out the front. Would the fan be facing the wrong direction? Or can you mount it facing either way?
Also, I guess it would hit the side of my case because it has a place to mount a side panel fan but there is a way to mod it for more space. If anyone knows how I would like some advice.
Also, the Nirvana seems to come with a cheap looking fan controller that dosent appear to mount anywhere. Can you set the fan speed and then unplug the controller with no problem?
