[SOLVED] Cooler for I7 4770
All 1150 coolers will fit. The socket size is standardised. If you have a LGA1150 CPU (4770) then any 1150 compatible CPU cooler will fit that socket. Obviously consider the size of the cooler and any fouls on other components/case.
So yes, the A30 will fit onto that socket.
