COOLER FOR i7 6700k
RidiRax
Commendable
Mar 26, 2016
7
Is the Dark Rock tf compatible with my Intel i7 6700k? And if not what other air coolers are good for this processor? Thank you
Yes, the TF is compatible with an i7-6700K.
What are you trying to achieve with it? Just looking for a basic cooler to run at stock speeds? Or push an overclock?
If you're just looking for a basic cooler, the TF will be fine. If you want something more substantial for overclocking, a location, budget & the case you're using will be helpful.
