Elkethus Commendable Apr 24, 2016 40 0 1,530 Apr 25, 2016 #1 I am about to get a cpu cooler for my i7 4970k do the h60 is a good 1 in long therm and to keep it normal temperature?
Solution Dark Lord of Tech Apr 25, 2016 PCPartPicker part list / Price breakdown by merchant CPU Cooler: be quiet! PURE ROCK 51.7 CFM Sleeve Bearing CPU Cooler ($49.99 @ BestDirect) Total: $49.99 Prices include shipping, taxes, and discounts when available Generated by PCPartPicker 2016-04-25 15:53 EDT-0400
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 Apr 25, 2016 #2 Even budget Air Coolers perform better and the H60 is loud. Upvote 0 Downvote
Elkethus Commendable Apr 24, 2016 40 0 1,530 Apr 25, 2016 #3 Even budget Air Coolers perform better and the H60 is loud. which 1 would you recommend me? my motherboardis a Z97-A Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 Apr 25, 2016 #4 What case ? Upvote 0 Downvote
Elkethus Commendable Apr 24, 2016 40 0 1,530 Apr 25, 2016 #5 What case ? http://ca.pcpartpicker.com/part/corsair-case-cc9011052ww this 1 Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 Apr 25, 2016 Solution #6 PCPartPicker part list / Price breakdown by merchant CPU Cooler: be quiet! PURE ROCK 51.7 CFM Sleeve Bearing CPU Cooler ($49.99 @ BestDirect) Total: $49.99 Prices include shipping, taxes, and discounts when available Generated by PCPartPicker 2016-04-25 15:53 EDT-0400 Upvote 0 Downvote Solution
Elkethus Commendable Apr 24, 2016 40 0 1,530 Apr 25, 2016 #7 PCPartPicker part list / Price breakdown by merchant CPU Cooler: be quiet! PURE ROCK 51.7 CFM Sleeve Bearing CPU Cooler ($49.99 @ BestDirect) Total: $49.99 Prices include shipping, taxes, and discounts when available Generated by PCPartPicker 2016-04-25 15:53 EDT-0400 big thanks ^.^ what do you think of thIS 1 http://www.newegg.ca/Product/Product.aspx?Item=N82E16835103099&cm_re=hyper_evo_air_cooler-_-35-103-099-_-Product I HEAR GOOD THING ABOUT THIS 1 ASWELL sory caps locked lol Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 Apr 25, 2016 #8 It's a real tight fit , if the EVO fits , the Pure Rock is 4mm SHORTER , so fits in the Spec 03 . Upvote 1 Downvote
Elkethus Commendable Apr 24, 2016 40 0 1,530 Apr 25, 2016 #9 It's a real tight fit , if the EVO fits , the Pure Rock is 4mm SHORTER , so fits in the Spec 03 . so this cooler wont block my ram and will fit in my pc? Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 Apr 25, 2016 #10 How many modules and what slots are you currently using. If you can locate a Cryorig H7 it would be ideal. Upvote 0 Downvote
