Cooler installation was proper?
Game_man
Commendable
Dec 15, 2016
48
Tell me if it is visually detectable whether the intel CPU stock cooler installation was proper or not..Thx
I don't understand, but if it works then it is OK. Screws snug, doesn't rock back and forth, may rotate a small amount slipping on the heat conductive snot, temperatures stay reasonable, screws are inserted equally (not one screw in too far to create a tilt and create an air gap (you'll know that cause it won't cool). Is there something bizarre with your assembly? Tell us more.
