Cooler Master 212 evo vs 412s
Rene Matuscak
28
Hello I am buying pc and I want to know which cpu cooler to get I am going to play mostly extreme games like the witcher, gta 5 arma 3 and so on and these games have a lot of heat so I need really go cpu cooler to lower the temperature. which one do you recommend and why? thanks
It doesn't matter which game you play, the CPU temp under load will mostly be really similar in most situations.
If you're not overclocking then the stock cooler is fine if you're getting an Intel CPU.
412S is slightly better but is slightly higher aswell (160mm).
thanks for answer I am having now gtx 560 ti i7 3770k intel stock cooler and when I play some games the fan on cpu is really loud which means it has to spin like 4500 to 5000 rpm and its hot like 80celsium and no I will stay at 4.0ghz I am not thinking about overclocking. and if you know can you tell me if that 412s will fit into corsair graphite 760t case? thank you
