As the title says, I'm looking at these two cases. I also could consider the CM HAF 922 (the smaller one).
The build would be a P55 Mobo probably a Gigabyte GA-P55A-UD4P. Core i7 860. and an ATI 5850 based vid card. Would have a tower type CPU heat sync (CM 212 being the current choice). Have no need for liquid cooling. Would have a 1TB hard drive and a 60-80GB SSD for a boot drive. External drives ill probably be a couple of opticals (like to have a source/destination pair), and a flash card reader.
Both cases would easily fit this hardware, plus significantly more. Both have the major features I want. Good cable management (with back panel routing), top-front mounted control/connector panels, toolless component installation, enough fans to get airborne under there own power. Etc., etc.. Actually, they have more in common than not. Both cost right at $100.
The CM seems to be a little ahead in the bells and whisles department (a front mounted esata port + the top quick connect drive mount. The LL might be a bit better quality.
So, anyone do builds with these yet? The CM is VERY new. Anyone have a preference (and why)?
