Hello Wise Ones!
I'm in the middle of building my first machine, and I'm modding an old Compaq ATX(ish) case (I want a desktop case, and new ones are too small to fit everything and get good airflow).
So, I'm cutting the case to create a mount for my Cooler Master Silent Pro M700- which way does the fan go?
I'm assuming that the fan sucks air from inside the case and exhausts it out the back. I've seen some pictures of builds where the fan is oriented to the top/bottom of the case. Is this correct, or should the fan point towards the inside? Does it matter?
Thanks!
Thanks!
