Cooler Master 840 ATCS Project
MonsterMawd
807
I've started the build for Cooler Master's media suite at 2010 CES. The D-9 concept was mine after seeing the movie.
I should know by first week of November what hardware CM will be sending me.
Conceptual drawing by E.E.L. Ambiense
Case Mods & Supplies used in this project by Mnpctech.com
Machined Aluminum Computer Case Feet Link
Acoustical Sound Proofing Sheets for your PC
Mnpctech is now stocking clear and colored sheets of cast acrylic for window mods
http://www.mnpctech.com/colored_acrylic_sheet_casemod_window.html
This is the Honeycomb Modders Mesh we used.
PC Cable management clamps
http://www.mnpctech.com/CableClamp.html
http://www.mnpctech.com/Computer_Billet_Fan_Grills.html
http://www.mnpctech.com/Computer_Fan_Grills_Laser_PC_Fan_Grills.html
The canvas for this PC build is the Cooler Master 840 ATCS
Adding window to Cooler master 840 ATCS
Using tape roll to make curved corner
Make first initial cut with your Dremel and cutting wheel, to allow use of Jigsaw and cut the window more efficiently
You have created slot, this allows using a Jigsaw w/ 18 TPI cutting blade
Using a Jigsaw is much quicker than using a Dremel to cut your window
Upgrading the 840's stock 120mm exhaust fan to 140mm fan.
Cooler Master 840 ATCS rear 120mm exhaust
I'm holding up a 140mm Cooler Master fan over the stock 120mm grill. "Will it fit without anything obstructing it?"
The location of the 140mm fan resides along the crease on the back plate.
Making the initial cut with Rotary tool and reinforced cutting wheel before using Jigsaw
Using Jigsaw with 18 TPI metal cutting blade
Using rounded side hand file to clean up burrs along the edge of the cut.
140mm opening is cleaned up, next is drilling mounting holes for 140mm fan
vibration dampening fan grommets
Using a 1/4" size drill bit to make the mounting holes, this allows the fan grommets to fit.
Vibration dampening fan grommets installed.
I've cut the window from Lexan. It's tougher than plexiglass/acrylic, but 2 or 3 times more expensive. It won't shatter or crack "easily" You can buy Lexan sheets at Home Depot, Lowes and some hardware stores like Ace.
The window will be fastened with 1/4" socket head screws, for reinforced armour look
Using center punch to mark each fastener hole.
Roper Whitney No. 5 Jr Hand Punch kit available here
Hand punch (estimate $60 new)
"Look Ma, No deburring needed!"
The benefit of using Lexan is that you can drill or hand punch it without cracking it.
Clean hole cut! I love Lexan.
Ironically our concept drawing calls for bullet holes in the Lexan "bullet proof" window...lol
Cooler Master's hardware list for their CES show display
1 x Intel Core 2 Duo E8500 Wolfdale 3.16GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor
1 x Intel Extreme Series DX48BT2 X48 Motherboard
1 x Silent Pro RS-600-AMBA-D3
1 x CM MITX Cooler 38mm tall (will be replaced with future V series cooler)
1 x Sapphire ATI Radeon 4870 512MB
1 x 4GB DDR3 Kingston 1600mhz memory kit
1 x WD 500GB HDD
1 x DVD drive
Silent Pro RS-600 Watt-AMBA-D3 PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171036
Are you a fan of the Black Ribbon power cables?
The concept called for bullet holes in the window
Using 3/8" drill bit
Using wire cutter to make cracks around the hole
Etching Rotary Tool (or Dremel) Engraving Bits
Using the dremel to emulate some cracks
CM is planning to show their new V-series cooler, they wouldn't reveal the model to me. I may rig a Cat Food can as cpu cooler, just for joke when they open the case....lol Cooler Master only sent 1 hard drive, so no sense in keeping the HD bay!
Use 1/8" drill bit to remove HD bay
1/4" thick acrylic sheets will act as reinforced segments of the side panels.
Heres a close up of the vertical blade cutting 1/4" acrylic sheet
These edges are not acceptable
Black & Decker Mouse Sander with Medium grit sandpaper
Thats better!
Starting on other side tonight, this side still needs exploded hole, and I need to get more 1/4" socket head screws. Those will be countersunk
Thank you, you should wear safety glasses. I can't cover up the bullet holes..lol
I used the Dremel with a cutting wheel to emulate impact to the reinforcement panel.
Using Dremel with egraving bit to gouge the other bullet hole under the acrylic. A ventilation hole was added as well.
Round Modders Mesh used as the ventilation grill in the left side panel.
Scotch Weld DP-190 2 part epoxy is used to attach the Modders Mesh to the backside of the side panel
Here is some screen shots taken from the movie trailer on Youtube. I think it's important to have the prawn canister implemented into the case. If Cooler Master had requested watercooling, it would been fun to make a reservoir based on the canister, but the system will be air cooled. We have some 2" diameter solid rod on hand we could use to re-create something close to it. I have some ideas, but want to have it my hands first before I commit to them.
