Question COOLER MASTER Cosmos C700M & COOLER MASTER ML360R Vibration Sound
mrtylnzzz
13
So I am kinda having trouble solving this issue. There is constant annoying sound caused by the vibration of aio fans. Sound goes away as soon as I touch top layer of the case. I tried tightening screws but it did not help. Anyone else having similar issue? Any suggestion is welcome.
Case: COOLER MASTER Cosmos C700M
AIO Cooler: COOLER MASTER ML360R
Here is a short video showing how it sounds and how it stops whenever I touch a little.
If you twist your case a little at the top does it make the sound go away? What is the case sitting on? If it is on a hard surface try putting an unused mouse mat under it to see if it helps. If you have any round rubber washers that you could screw down under the top mounting screws may help also.
