Cooler Master Extreme Power Plus 600
Toxxyc
969
76
Agreed with jsc. Extreme Power series from Cooler Master is their cheapest one, and not recommended for gaming rigs. Rather go with their GX series, Silent Power Pro or Silent Pro series. They are more expensive, but they are also better built and provide better efficiency than the Extreme Power series.
Yes that psu will run that card but not very efficiently.And it's not a 600W unit it produces just shy of 550W.
http://www.hardwaresecrets.com/article/Cooler-Master-eXtreme-Power-Plus-600-W-Power-Supply-Review/1034/9
Cooler Master GX models aren't really much better and offer mediocre performance for the price.
Here's a GX 650 review
http://www.hardocp.com/article/2010/11/22/cooler_master_gx_650w_power_supply_review/1
If you're looking for cheaper good quality units i would look for an OZC.
Antec and Corsair make very good units but cost more.
shubhankar_venkatesh
140
@Davcon : No very efficiently in the sense ?? Well I plan to run a system with 6 hdd internal and a 6870 Radeon ?? Which PSu I should go for. Suggest cheap and good budget is limited within 5k INR.
http://www.theitdepot.com/details-Antec+EarthWatts+650W+Power+Supply+(EA650)_C14P3404.html
http://techshop.in/store/corsair-cmpsu550vx-power-supply-buy-online-india-p-2930.html?cPath=320_194
The Antec and the VX550 are really great units.
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=110
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=62
140
Well the Graphics card mentioned above requires 2 * (6+2)pin 75 W power connetors. None of the above meintioned power supplies have such specification Can I go for Cooler Master M600 Silent Pro ??
They certainly do!you'll only need two 6pin the 6+2 lead is for high-end cards.
Both units have that as well.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004
http://www.corsair.com/power-supplies/non-modular-psus/enthusiast-series-1/vx550w.html
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371015
http://www.antec.com/Believe_it/connectors.php?ProdID=27650
The Corsair TX is also very good.
Toxxyc
969
76
Cooler Master Silent Pro is overpriced IMHO. Antec HCG would do you well also. And you can then twist for a slightly more powerful PSU for the same price as the Silent Pro.
