Cooler master gpu bracket/expansion slot panel
vemmu.tauriainen
There is this coolermaster vertical gpu bracket.. but what does cooler masters orginal bracket look like? Is it one solid piece to put in place with 2 screws
Im intrested because the orginal cooler master pci/gpu bracket would be solution if you had modified ur case thats not CM product and wanted go back normal gpu fitment.
