Cooler Master GX 750W II 80+ with Z77 extreme 4 Mobo
a_drake
43
Hi ive had this problem for about a year now and only deciding to do something about it I have
Cooler Master GX 750W II and a Z77 Mobo that im using problem is the 20+ 4 pin connector wont connect into the mobo so im left running only the 20 pin. Im wanting to start overclocking and the guy and the IT store told me the 20pin wont be able to overclock with it ill need the 4pin as well is this right and can anyone shed light on my problem thx.
He said that the 4 pin wont connect into the mobo which is why only 20 pin is connected which i find strange
When the guy was doing it he said the o connectors and D connectors were around the wrong way if that makes sense
Ok couple of things looks like all the pins are connected in the right spot and i have a cm 750w gx not 750w gx 2 is this still okay for over clocking? Also a reliable video on how to get me started over clocking if you have any?
