The drive cage in the case is the exact same drive cage found in the MasterBox 5 chassis:
If you want to show off the SSD, you could either be creative and align the SSD with the notches on the slits/holes atop the drive cage or you could get the SSD caddy
I actually can't find a link to the part because it's not sold as a spare case part by CoolerMaster. Instead I was sponsored by CoolerMaster and I asked for that part specifically. You could try Ebay. To add, that caddy houses two 2.5" drives. Like I mentioned earlier, you can try and work with the holes atop the HDD cage or rather look at a case that allows you to show off the SSD's RGB. You could look at SSD's mounted to the motherboard wall that face the viewable end of the side panel in a case...?
