Cooler Master HAF 912 model# RC-912-KWN2
uves2112
Commendable
Jun 20, 2016
7
Hello,
Wondering if a MSI gtx 1070 Twin frozr fit in Cooler Master HAF 912 model# RC-912-KWN2. I am confused as I currently have a gtx 970 and the specifications for 1070 dimension are almost double of 970.
Please help.
Man, you're lucky to have found the windowed version. My HAF 912 would love a windowed side panel. But I digress...
Yes, the card will fit fine. You have 270mm / 10.6 inch (with HDD cage), and 390mm / 15.4" (without the 1st HDD cage). I had to remove the drive cage on mine for some long cards. The MSI card mentioned above is 279mm long, so you'll probably have to remove the drive cage.
