ok so I've decided to get this case with my Build.. But it says it takes ;
1 x 230mm front red LED fan
1 x 230mm top fan
1 x 230mm side fan
But its compatible with
Cooling System
Front: 230 x 30 mm red LED fan x 1, 700 RPM, 110 CFM, 19 dBA
Side: 230 x 30 mm standard fan x 1, 700 RPM, 110 CFM, 19 dBA (support 120 x 25 fan x 4)
Top: 230 x 30 mm standard fan x 1, 700 RPM, 110 CFM, 19 dBA (support 120 mm fan x 3 or 120 mm x 1 + 230 x 30 mm x 1)
Rear: 140 x 25 mm standard fan x 1, 1200 RPM, 60 CFM, 17 dBA (support 120 mm fan x 1), 35,000 hours life expectancy
Ok.. So explain this if you will.. for the Front it HAS to be 230mm.. The side can have 4 - 120mm fans.. the Top can have 3 - 120mm fans or 1- 120mm + 230mm fan.. and back just 1 120mm or 140mm?
I can't find ANY 230mm fans on newegg.. Am i just overlooking something?? It seems like it would be a lot better if i were to just get the big ones instead of alot of small ones.. ( Less noise maby, and looks ).. I'm really wanting to get the green glow going on but i can just get the Cathodes so i Dont HAVE to have the fans green.. Any Cheapish suggestions for fans for this beast of a case?
1 x 230mm top fan
1 x 230mm side fan
Cooling System
