Cooler Master HAF-X Fan Compatibility
zacw812
56
I just ordered this case and im really confused about the different fan options. Eveyone says that this case has great cooling options and was wandered if i can only install 200 mm fans on the top?
I also ordered the 212 evo as my cpu cooler, so water cooling is out of the question. What would you guys recommend? Thanks guys
I am certain that you can only use 200 mm fans on the top. The 212 EVO is a great budget cooler and should be more than adequate.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103072
That is the fan I believe comes stock.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007998%20600035599&IsNodeId=1&name=200mm
That link is a list of fans that are compatible. I'd go for the Cooler Master or the NZXT ones.
