Cooler Master Hyper 212 EVO vs Hyper 212 Plus
invane
86
Good day Guys... Just wanted to ask a quick question.
Which would be better from the two?
1) Cooler Master Hyper 212 Plus (is additional fan necessary?)
2) Cooler Master Hyper 212 Evo (is additional fan necessary?)
Cpu: Intel Core i7 3770
No overclocking
Thank you guys
jemm
Technically speaking you won´t need an aftermarket CPU cooler, because your CPU can´t be overclocked.
However, if you live in a hot location, or your case has not a good air flow, or any issue regarding to temps, then it is a good idea to get a CPU cooler.
Hyper 212 Plus and EVO are basically the same, but with a few differences -- basically the fan in EVO fits better than the Plus. So, the EVO is better.
As for for an additional fan, it is not really necessary, tough if you place one you will get around 3~5 less degrees.
invane
86
@ jemm
Thank you very much for the quick response. I really appreciate it.
Saying adding additional fan can reduce 3-5 degrees is pretty nice. I live in
a very hot area...so i guess im gonna need an aftermarket cooling. Thanks again!
