Cooler Master hyper 212 Led turbo compatibility
Rick_MVP
59
I just bought the CM hyper 212 led turbo and it doesnt fit in my case as its 163 mm tall. So i was looking for a new case , dont wanna spend much, I was batting an eye over the Corsair Spec 2/3 , Corsair spec alpha , Cm masterbox 5 ( but it costs close to 100 USD in my country and i dont wanna spend that much) , the Nzxt s340, and the corsair carbide 270r . Which one will fit my hyper 212 turbo as 163 mm is really tall :3 . and if you guys could , suggest me some cases . oh, last , i even saw the deepcool Kendomen which is the cheapest outta all of those cases. thank you.
The CM Hyper 212 LED Turbo Version (at 163mm) will fit the Corsair 270R (max. 170mm) and the CM Masterbox 5 (max. 167mm) but it will not fit the Deepcool Kendomen (max. 160mm), the Corsair Spec-02 (max. 157mm), the Corsair Spec-03 (max. 157mm), the Corsair Spec Alpha (max. 156mm), or the NZXT S340 (max. 161mm). Note that the Non-Turbo Version (single fan) may fit some of the above cases.
Since you are on a budget, I'd go with the Corsair 270R if you can afford that.
Yeah its not as costly as the cm masterbox 5 here in India . Here the 270r costs around 70 USD so , yeah fits right into the budget , i was just concerned about the crappy red led fan they give with 270r which doesnt make sense to me. anyway thanks .
