[SOLVED] Cooler master hyper 212x fan not working
ashishdass1000
23
My cpu cooler cooler master hyper 212x been running for 5 years no problems but today the fan is not spinning even when i try to run it with my finger it was not moving so as this fan is not working i have case fans of same size i tried with the same cpu fan connector in motherboard nd they r working but issue is that how to make that case fan attach to the heatsink
The fan appears to clip to the heat sync.
Can you tell if the fan detaches from the bracket that clips o the heatsync.
