Cooler Master Hyper T4 Fan positioning
VSI2110
57
Currently Running with AMD Kaveri APU, on Fm2+ socket.
planning to get the Hyper T4 (The EVO212 will not fit in my case)
as per reviews ive seen, it seems that the T4 would fit the socket without the need to remove any backplate or anything, but this will mean the fan will be facing up, not the rear of the case (as i would prefer)
I would like to know if Cooler master Provides backplate and mounting so that i can position the Fan and the cooler blowing air to the rear of the case.
I have the t4 as well on my A85x FM2 mobo. It is fixed to either point up or down, thus, the logically choice would be to point the fan to exhaust heat upward.
On my 760k, I am able to OC to @ 4.6 stable with the T4 exhausting heat to the top. I also have a 140mm case fan on the top side.
I am using a Thermaltake's versa G2, with CPU cooler height limitation of 155mm only (Evo is 159mm Tall).
these corsairs memory i have are quite tall, i hope the T4 gives just enough clearance!
