Cooler master K380 Case Best water cooling system available
ibrahemahmed
11
Hello everyone i just finished building my pc using the Cooler master k380 computer case with the 500 watts power supply that came with it .
I'm using the FX-6300 AMD processor the only thing that i dont like so far is the heat sink that came with it . the fan is always running at 5600 RPM which is very noisy and keeping the pc only at ~50 C on load .
I'm looking for the best water cooling system that can fit in that CASE i was hoping to install the Seidon 240 MM but i dont see how can i get it to fit in the case another option is the 120mm version which will fit on the back fan .
how big is the difference between the 120mm and the 240mm i would assume twice the performance . currently i'm running at 3.5 ghz looking to run at 4.0-4.2 ghz with my current setup.
what do you guys think ?
i'm trying to run as quite as possible because i really hate fan noises and also the fan rpm is kinda low 600-2000 would that be enough
Sufficient!
I have OC'd 8350 which is a 125watt cpu ( 6300 is 95watt) to 4.4~4.5 GHz stable with Hyper 212 evo.
how about the noise ? and also would it fit in the k380 it is a BIG cooler also would it be worth it getting an aftermarket Fan or even a 2nd fan for that cooler . i see that it comes with a second mounting kit
that is correct guess i will have to look the seidon water coolers .
