Bought This Monster and it is fitted properly and safely
Well I have Managed To Install The Coolermaster Master Air 8 CPU Cooler In CM 690 III
Its perfectly installed in my CM 690 III as i was worried that it wont fit becouse cooler is big 172mm and on CM site it was given that CM 690III supports max of 171MM height CPU cooler
But its fit even there is still more gap after closing the side panel like
was using H100I previously now i got this monster and i am really impressed really... My I5 4670K Overclocked @4.4Ghz and max Temp after running prime 95 for 10 Min it wont exceed 60'C
and my ambient Temp are 35'C+ i am from India Newdelhi and its summer time very hot and humid
Here Are the Pictures
I was thinking to buy this CPU cooler will it fit in it?
If any one here is using it can you please post some photos. I was searching on google but no luck.
