cooler master masterBox 5 cooling
nikolas552
4
Hey, was just wondering if the masterbox 5 mid tower case's air flow and cooling ability would be enough for a stock clocked i7700k. At the moment ive got a Thermaltake Riing Silent 12 cooling the cpu and not really looking to jump into water cooling.
Will the masterbox 5 be ok with the cooling or should i look for a case with nicer airflow.
Thanks for any help.
Hi, you'll be just fine.
I have the Masterbox 5 White and i7 6700k with just a Cooler Master Hyper 103.
Idle temps are 27 degrees, while on quite a load it reaches 60-65 degrees.
Note- room temp is 27 degrees and I have 3 front intake fans and one exhaust fans.
I thinks its fine.
I thinks its fine.
