Cooler Master MasterBox Lite 5 Water cooling ?
Zatlon
50
Am going to buy this case the next month, it has good acoustics, and a very cheap price tag, however am also considering a custom water cooling in the future, the case supports up to 360mm radiators, but I cant find a place to put the pump/reservoir on ?
Is there a place for it ?
Ah... I was going by the price listed here which I guess is outta whack.
https://www.newegg.com/Product/Product.aspx?Item=9SIA50M6B83141
But, to be frank, that case is simply inadequate for water cooling. Forget the reservoir, it's inadequate for air cooling using any set of components that would warrant putting them in water. You have (4) 120mm fan mounts ... at 75 watts per fan, that's 300 watts ... a 1080 Ti draws more than that by itself.
Is this an ATX, mATX or ITX build ?
ATX - Phanteks P400 - $49
https://www.newegg.com/Product/Product.aspx?Item=N82E16811854029
Front: 3 x 120mm / 2 x 140mm (1 x 120mm fan included)
Top: 2 x 120mm / 140mm
Rear: 1 x 120mm (1 x 120mm fan included)
ATX Phanteks Enthoo Pro -...
It's not really well suited for water cooling.
http://www.coolermaster.com/case/mid-tower/masterbox-lite-5/
Front 240mm / 280mm / 360mm radiator (limited) up to 50mm thickness without fan
It also lists that you can put a 120mm on the rear but not really ... you need that fan to get air out of the case. For custom loops, I'd recommend that Phhanteks Enthoo line. Enthoo Evolv or Luxe
I know the radiators dimensions and it is acceptable, the problem is the reservoir
I appreciate your opinion, but for a 50$ it is not comparable for these cases, I have seen a reservoir with mounting to the motherboard tray below the ssd tray, cant it fit there ? am going to mount the case fans outside the case anyway for the rgb lights to shine and not show the case metal in the middle of them.
ATX Phanteks Enthoo Pro - $79
Front: 2 x 120mm fan
Top: 3 x 120mm fan
Rear: 1 x 120mm fan
Bottom: 2 x 120mm fan
HDD: 2 x 120mm fan
ITX - Phanteks Enthoo Evolv ITX $65
https://www.newegg.com/Product/Product.aspx?Item=N82E16811854016
Top: 2 x 120/140mm fan
Rear: 1 x 120/140mm fan
Front: 2 x 120/140mm or 1 x 200mm fan (1 x 200mm fan included)
As for your reservoir concerns
https://www.youtube.com/watch?v=Tvc2AiGmsQ0
https://www.youtube.com/watch?v=r5b2QKT72v8
https://www.youtube.com/watch?v=AOmIEQW1LuU
https://www.youtube.com/watch?v=RSmXRzBXWGc
That last one uses a Swiftech AIO which is a collection of Swiftech's custom water loop parts pre-assembled at the factor, with a reservoir. And yes, you can add a GPU water block (or get a MSI Seahawk EK w/ full cover water block pre-installed) and add a 240mm radiator in the front.
