[SOLVED] Cooler Master mastercase H100 ARGB
Has anyone built an itx system with the above case? Just wondering about temps,being a small case, heat is always going to be a problem. There is a 200mm fan in the front and Im only using a ryzen 3400G with a Noctua NH-L9a low profile fan and hope this will be ok. Im in the UK so high temps is not an issue, it's just a simple system for my daughter,she's only 9 so its not like she's going to be putting the PC through hell and back.
If she's not gonna really extensively use the PC, then It's fine. Your case should be fine if it's mesh. Noctua NH-L9 series are well known for a good reputation on cooling cpus well.
Reactions: kurdtnz
