Cooler Master MasterLiquid Maker 92 Front Fan
Jul 21, 2018
Hey guys,
I have plugged in everything seemingly correct and my rear fan is working fine, so i see no reason for the front fan to work. It is plugged into this AIO cooling unit correctly as shown in all the documentation that I have found but, for some reason it doesn't want to work.
Do you guys think Cooler Master may have sent me a faulty fan?
Thanks,
Nate.
Regarding the splitter used to pair a Fan header and the SATA power connector, is the FAN header on your board used a CPU_FAN header?
Might want to show us a pic of how you're connected, for both the fans and the AIO's power and signal cable, if you've followed through the manual, accordingly.
It is in fact connected to the cpu fan header, and the sata power is also connected. I would take a picture but you cannot see it because of how small my mini-itx case is. The AIO is getting power and the pump is working. The rear exhaust fan is also working just not the front. I have ran benchmarks and temps are all good but, it is slighlty irritating that I cannot get the intake fan to do anything.
