[SOLVED] Cooler Master MasterWatt 700W or Thermaltake Smart 700W?
pg1312
20
Which one of the two PSU's is good at buying in your opinions?
My PC Specs:
Intel Core i7 8700K
Asus Rog Strix VEGA 64
Team Group T-Force DELTA RGB
MOBO Gigabyte B360 Aorus Gaming 3
Thanks in advance!
You could try to narrow down your searches using filters on sites like PCPartPicker.com or simply use Newegg. This PSU Tier list will tell you which series of power supplies to avoid. Do mind, it doesn't include all power supplies (especially newer series). But the ThermalTake one you mentioned is Tier F. The CM one is Tier D, so at least a little better. You're not going to find a Tier S for 100 bucks or less. The SeaSonic Focus Plus line is a very good line of power supplies.
https://linustechtips.com/main/topic/986897-psu-tier-list-21-legacy/
