C carlowan611 Sep 9, 2018 3 0 10 Oct 8, 2018 #1 Hey guys, quick question I just noticed today my cooler master aio cooler ML240r's pump is quite warm. Is that normal? I read a few thread that the aio cooler pumps shouldn't be warm. Any one experienced this? Any help much appreciated.
Solution julienruc Oct 8, 2018 Might be worth getting a good thermal paste like the Thermal Grizzly Kryonaut. Try and find a software thay can read the AIO's temps if that even exists. Check mobo temps. See if it's onky hot around the pump or everywhere. Check if pump somehow got loose because u didn't tighten the screws in the first place. Sometimes it'll loosen up as time goes by.
julienruc Honorable Aug 8, 2018 1,682 78 13,540 Oct 8, 2018 Solution #2 Might be worth getting a good thermal paste like the Thermal Grizzly Kryonaut. Try and find a software thay can read the AIO's temps if that even exists. Check mobo temps. See if it's onky hot around the pump or everywhere. Check if pump somehow got loose because u didn't tighten the screws in the first place. Sometimes it'll loosen up as time goes by. Upvote 0 Downvote Solution
