[SOLVED] Cooler Master MWE 750 80+ Gold Modular... is it worth it?
Mar 19, 2019
Hi,
I found the Cooler Master MWE 750 Gold Full modular for about $86 USD last week and made a hasty purchase, as it sounded really good with its 80+ Gold rating and was full modular. However, I didn't look it up prior to my purchase and now I am confused if I should get it replaced with a Corsair RM750x or is it a good purchase.
The reasons I looked up the RM750X in the first place was that it was listed in pretty much on all the Best PSU articles that I looked up and on the other hand, I didn't really find any good reviews of the CM MWE 750 that I bought. I know the CM MWE 750 is relatively new but still.
I currently have:
  • Asus Maximus VIII
  • 6600k @ 4.8ghz
  • Zotac GTX1060 amp 6gigs
  • 2 x Samsumg 500 gig ssds
  • WD 3T Purple
  • Enermax 650 80+ Bronze PSU
I am Planing to upgrade to:
  • Asus Maximus xi Hero
  • 8700k
  • May be GTX 2070
Thanks in advance.
Even with the upgrade 650W will be fine. Gold is only an efficiency std.
I am more concerned about either this PSU that I got is a good product....I can save some more and get the corsair RM instead of having this Cooler master die and take out something with it...
Just not sure if i should stick to it..
