I got that Q300l case on the way and I want to make sure it's adequately cooled as it seems to the the weak point. I also have a AsRock B450M Pro4 mobo. Also trying to do this as economically as possible cause I've already blown the budget.
I can get a 5 pack of 120mm fans and install a fan in every place the case can accept one. I originally was going to install 2 140mm fans in the front and 1 120mm on the top but saw these Deep Cool RF120 five pack on amazon. But seems like 5 fans for a better price than 3 is a no brainer.
https://www.amazon.ca/DEEPCOOL-Compatible-Controlled-Motherboard-Controller/dp/B07HN199YJ/ref=sr_1_6?keywords=case+fans&qid=1583536561&sr=8-6&th=1
I don't really know anything about hooking these up. Heres what I got on my mobo
I should be able to daisy chain those fans so I shouldn't need to buy a hub or other extra stuff right?
- 1 x RGB LED Header*
- 1 x Addressable LED Header**
- 1 x CPU Fan Connector (4-pin)****
- 3 x Chassis/Water Pump Fan Connectors (4-pin) (Smart Fan Speed Control)**
