Cooler Master Seidon 120M too loud
Ivan Despot
8
Hi guys,
Today I replaced my Intel stock cooler with a Cooler Master Seidon 120M. I knew that Seidon can be noisy from before as i heard it operating on a friends computer, but on my setup its too loud 🙁. The noise is constant from the powering on and constantly at cca 1480 RPM (although i thought max is 2400). I checked the set up twice, everything should be at it's place, the pins, right connectors and in BIOS fan controllers are on AUTO.
One other thing, with the stock cooler I had temperatures around 37, max at 40ish when playing games, however when i played today with Seidon temps were even higher (cca 50ish)...
Processor: Intel C2D E8400
MBO: Asus wifi p5ke - wifi
I would appreciate any kind of help or suggestions on how to solve this issue.
i sure am thinking about replacing the CM original fan, however that doesn't solve the issue, since i know for a fact that Seidon doesn't make that kind of loud noise + why is it operating constantly at 148 rpms :S
