Cooler Master Seidon 120v sound
Pagesset
39
Lastly, my 2 months old computer started doing a water noise. It's not normal water flowing noise, it's a quite low noise which appears every 2 seconds. I know it's water flowing, but I think it may be air inside or something like that. Is it a big problem? Will I have to change my cooler?
I've been on this forum since early 2009. I've never read of an AIO exploding. Not even leaking even (although it wouldn't be unheard of, I guess). Besides, there's nothing to "explode". It is just a tiny pump circulating a small amount of coolant from heat sink to radiator in a loop.
I will change it to a air cooler but in a month. Do you think the water cooling will "explode" or something in a month of use?
No. But cooling performance my suffer.
As far as I've seen it''s not a really big sound, it''s just when you put your ear on it. I will keep it in my computer until temps get bad. It won't explode, right? I have read horror stories about watercooling. My watercooler does a little sound which is just noticeable when you put the ear on it. So, should I worry for the security of my computer? I mean, it won't explode, right? Or, it won't have water leaks, right?
