Cooler Master Silencio 352 case - add fans or not?
Ags1
255
This small, sound (and heat) insulated case comes with a front 120mm In fan and and a rear 120mm OUT fan. I have a 65 Watt CPU and I will add something similar to a GTX970. I can add a third OUT fan on the top of the case.
Adding the fan will improve airflow, but the negative pressure might counteract the direct heat exhaust of the GTX970... What would be the best thing to do?
Add a 120mm to the front of the case blowing in 2 will fit in the front, then you should be good to go.
Top: 120x15mm fan x 1 (optional) Front: 120mm fan x 2 (one XtraFlo fan (no LED) installed, one optional) Rear: 120mm XtraFlo fan (no LED) x 1 (installed)
