[SOLVED] Cooler Master SL600M case query
Yarberger1
60
Hi everyone
Does anybody know whether a sound card can be installed within the Cooler Master SL600M case if the GPU is mounted vertically? I don't know whether there would be enough room.
Thanks!
I would say so, but motherboard layouts can vary so it depends which board we are talking about.
In this photo -
You can see there is a small PCIE slot available at the top, and i think if you plugged the riser in a lower PCIE slot you could use the top one for a soundcard.
In this photo -
