Cooler master storm scout front fan replacement
-Zombie-
24
I can't find any information anywhere on if a 200MM fan will fit on the front of the storm scout case.
I think the stock fan is 140MM, I would really like to have a 200MM on there. Can anyone help?
the scout has pre-drilled holes for a 140mm fan or a 120mm fan. And you are correct the stock fan is 140mm.
But as amuffin said, you can drill some holes in it to make a 200mm fit. There is enough room for a 200mm it just dose not have the holes :)
Hope this helps!
thux
26
Hope this helps!
