Cooler Master Storm Stryker. Issues with top panel Power Switch button
AnhLTran
6
Hey all,
I have an issue here. While the fans that came with the top panel work just fine, the power/ reset buttons just don't. I can still turn on the computer using the power button on the motherboard, but when I press the power up from the front panel, nothing happens. I already to re-plugging the power sw/ reset sw multiple times.
The motherboard I'm using is Asus Z9pe-d8 ws.
Anyway, I was wondering if anyone has owned this case and/or can give me some advice as how to start fixing this. I hope to hear from someone. Thanks.
Anh
If you have them plugged in correctly and it doesn't work, chances are it's broken. You tried switching them around? They have to face the right way. Read your mobo's manual, it should tell you the exact way to plug them in.
I tried switching them around and found out that this problem is due to the 2-pin on the motherboard 🙁. Is there any way to fix this?
