Cooler Master Thunder 500W fan not spinning
Aug 15, 2013
24
Hi
I recently brought a new Cooler master thunder 500W PSU wit Amd radeon r7 260X, Having issue with the PSU, Fan of the PSU is not working some times it work some times it wont and while playing game PSU is getting hot, is this normal please help me out...
My Specs
Processor : Amd phenom 2 X6 1055t
Motherboard : Asus m4n68t le v2
RAM : 4GB
HDD : 500GB
GPU : Asus Amd radeon R7 260X
Thank you
Some of the newer PSU have built in thermal fans that only turn on when unit needs to be cooled. This is likely whats happening to yours. There should be a switch on it somewhere that will allow you to switch it to "always on".
Thnx Finkledbody but its getting hot is this normal ???
how hot is it getting? warm to the touch? to hot for you to keep your hand on it?
It would be best if you have a laser or a infrared thermometer that you could be able to check to see how hot it is actually getting. You might just be over reacting.
Thanx Finkledbody, sorry i dont have infrared or laser thermometer i'm browsing for 4hrs and i can touch it it jst warm, but let me see while playing games..
Since half an hour im playing Tomb Raider and the PSU fan is still not spinning and its warm i can touch the PSU, hope this is normal to get little heat..
