Cutme774 :
Should I just get the Seasonic x750?
That's a little different than with what you started with. As said get a good 650watt for one card and if you want to go for crossfire in the future get a good 850watt.If the cooler master is the really cheaper one just get that one.Here in Holland for instance is the cooler master the really cheaper option.
If you don't go for crossfire,but the price difference between a V700 or X650 and for instance the 750watt versions (for cooler master is there no 750watt (or you must be looking at the
semi modular ones=vsm,still good units) isn't that big is it up to you to decide to for which one,but you really don't need 750watts with just one gpu.
If the price differenc is good would i just go for the cooler master psu.They have a bad rep here on the forum,but they also make good psu's.They just had/have their (really) bad series,but so does corsair for instance (if you read enough about the cx for instance,actually not that bad,just not that good either).
