What is your budget? If you want silence, anything by Noctua will serve you well! However, you can go with a cooler master hyper 212+ and replace the fans with silent fans! I prefer the Cougar Vortex 120mm fans!
well, i was planning on getting a zalman z11 plus for a case. the cooler just has to be silent, the fans you suggested seem like some really good ones. I probably will use one of them but if you know any better ones please respond. It doesn't need to be all that powerful since wasn't planning to overclock.
