Question Coolermaster hyper 212x with static pressure fans
Karadjgne
Herald
You won't find a fan that works. As is.
That cooler uses a standard 120mm x 25mm fan. Any fan you like that's 120mm will physically mount to that heatsink. The issue is the mount. Fans come by themselves, they do not include mounting brackets or clips to mount to heatsinks. If your heatsink did not come with a bracket/clip to mount a 2nd fan, then you'll need to figure some alternate way (ziptie) to mount the fan.
Apr 13, 2019
31
The cooler come with extra brackets for the 2nd fan.
