Question Coolermaster MB520 Rgb fan connection
Apr 25, 2019
22
Hello
Im trying to make my first build with a coolermaster mb520 rgb case however i coultn figure out where to plug in the rgb fan cable.
There are 3 fans in front of the case and 2 seperate group of cables are coming from them.
The first group has 3 seperate cables with 3 pins which are connected to a molex adapter. The cables are preassembled like this.
The second group has 3 cables which both connect to common adapter which then ends with a female cable with 4 pins.
I thought that I should plug the molex cable to the psu and the female cable from the other group to the JRGB slot in the motherboard. Is this correct? I didnt open the pc yet.
