S suitlover39 Apr 16, 2018 1 0 10 Apr 16, 2018 #1 I recently updated my bios on my amd ryzen 3 1200 system and the aio is now running at ridiculously high rpm and its extremely loud. I have no idea how to turn down the rpm. Any help is appreciated. Thanks!
Solution rodolphe.viard Apr 17, 2018 Hi suitlover39, During bios update, you can loose some parameters entered in bios. So, you could check in your bios, where you control your Fan Speed to set a custom temp/RPM curve. Rodolphe.
rodolphe.viard Reputable Feb 27, 2018 292 0 4,960 Apr 17, 2018 Solution #2 Hi suitlover39, During bios update, you can loose some parameters entered in bios. So, you could check in your bios, where you control your Fan Speed to set a custom temp/RPM curve. Rodolphe. Upvote 0 Downvote Solution
