Folks,
I just purchased a new Asus motherboard and a CoolerMaster Elite Power 460W Power supply. The motherboard has a 3-pin PWR_FAN connector. However, the PSU does not have any cable that would fit this connector. Is it safe to power on the motherboard without this connection?
Also, a cable coming out of the PSU is called "CPU 4+4 Pin Connector." The pin description says COM, COM, +12V, +12V. I don't see any connector on the motherboard that will take this cable. What is this for? Is it okay not to connect this cable?
Thank you in advance for your help.
Regards,
Peter
Regards,
Peter
